Markus -
The "Locals.DatabaseOptions.DatabaseSchema.Statements[3].TypesToLog" property in the SinglePass and TestUUT sequences hold the specific schema data that you are talking about that the database logging uses. If you are trying to access this from other than the entry point sequence you could use "RunState.Root.Locals.DatabaseOptions.DatabaseSchema.Statements[3].TypesToLog".
You can either hardcode the index of 3, or you will have to find the statement by name by looking at their Name subproperty. The syntax of the TypesToLog string value is a comma delimited list of types.
Hope this helps...
Scott Richardson (NI)
Scott Richardson
