I am working with TestStand 3.1. For the report generation I am using the horizontal.xls stylesheet. But when using this stylesheet, all steps of the test sequence are displayed in the report, including the "Done" steps, e.g. the flow control.
It would be fine if only the "Passed" and "Failed" steps are displayed. Unfortunately there is no possibility to modify the "result filtering expressions". This is only possible if you are using the html report format.
Now my question: Is there any possibility to realise a xml report format, which only shows the "passed" and "failed" steps?
Thanks for your help
Daniel
