03-09-2006 08:48 AM
03-09-2006 12:51 PM
03-19-2006 05:10 AM
03-24-2006 04:25 AM
We have installed CVI8.0.0.273 runtime engine and we still have crashes on some Message Popups in SeqEdit.
Here is a short description of the system : we have a PXI 1000B chassis connected to the computer with a PCI and a PXI MXI-3 (software v1.15).
PXI cards : 2 PXI CAN 8461/2 (one dedicated to DiagOnCAN and the other one for CAN), 1 PXI 6070E, 1 PXI 6713, 1 PXI 6704, 1 PXI GPIB. We also have 2 PCI cards : Addi-Data APCI 2032 which drive the relays of the system. We have installed DAQ-mx 8.0 (DAQ 7.4.0 is also used on the system for an other application, not with TestStand), NI-488.2 2.43 and NI-CAN 2.3.2.
Our application is multithreaded (3 threads + 1 main thread).
We have tried several solutions not to use the step "MessagePopup" of TestStand : we have created a specific step calling a CVI dll. In this dll we call the CVI MessagePopup function, but TestStand still crashes. Next we have tried to display a panel (created in a uir file) instead of the Popup but the problem is not solved (we tried several combinations of panel attributes).
In Windows TaskManager we see that the PIV 3.2GHz HT is never overloaded (CPU load = about 90%) and that there is enough memory available on the system.
If we try to run a sequence that creates 3 threads which process nothing (infinite loops), with no signals / CAN / instruments processing, we can't reproduce the crash caused by the Popups.
Do you have any suggestion about that ?
03-24-2006 04:31 PM
03-27-2006 03:58 AM
