Hello to all,
I am failrly new to TestStand and have a question
Prior to begining the Test Sequence, I am prompting the operator with a Message box to select the part number that they will be using to test. How can I output this information out of the message box so that It can retrieve the correct file that I will be calling and also display that number on the Base Name of the Report, (where report options is located)?
