Hi everyone
I would like to launch a Matlab function from teststand 3.1.
In order to do so, I try to use the ActiveX/COM 'Matlab application (6.5) Type library (1.0)
Then I use the object MLEVal, the method then to use is XLEVal
This method requests different parameters such as :
BstrName, Nargout, pvargout, nargin and varargin.
Passing one parameter doesn't represent any problem and work fine.
However, if I want to pass more than one, then Matlab doesn't understand that 2 or more parameters
are present. I know it because I use the varargin variable in my Matlab function declaration.
I tried to pass arrays, container from Teststand nothing work
Does someone have the solution ?
Thanks a lot
Lars
