05-09-2012 08:20 AM
I'm using TestStand 2010 and LabVIEW 2010.
One test (sequence) calls VIs that control Agilent 16900A logic analyzer: run and stop (Stop VI is attached for example).
These VIs use ActiveX - LA COM Automation client software.
Everything worked properly, until I switched the LabVIEW adapter from "Development System" to "LabVIEW Run-Time Engine" (in order to make deployment).
When a step that call the logic control VI is executed, I have got the error ”SmartHeap Library - MEM_BAD_POINTER", then "SmartHeap Library - SmartHeap error handler recursively re-entered"- and TestStand is crushed.
Never saw the such problem before.
Any help is appreciated!
05-10-2012 05:00 PM
Hey Berezka,
Have you tried to isolate the problem to see if it's something that occurs just inside LabVIEW? Would it be possible for you to create a sample VI based on the VI you're having problems with, that runs in LabVIEW, and try deploying this VI from LabVIEW using the LabVIEW Run-Time Engine? Do you experience these errors from LabVIEW, either running the VI in the LabVIEW development environment or from a LabVIEW deployment?
The key here is to see if we can narrow down the source of this error.
05-12-2012 05:23 PM
Hi Courtney,
This VI works fine in LabVIEW, I even built EXE based on this VI - it works too.
In the meantime I tried to connect with the logic via Visual C++ using the same LA COM Automation client software.
Wrote DLL with functions Run and Stop, created 2 steps in the TS sequence - the both call the DLL Stop function, loaded dynamically and unloaded when step is finished.
The first call is performed, the second call causes the "MEM_BAD_POINTER" error etc.
If the sequence has only one call to the DLL function (e.g. Stop) - I may run it several times successfully.
05-14-2012 09:28 PM
Hi Berezka,
Would it be possible to get a screenshot of the error? This isn't one that I've encountered before so it will help me research what could be going wrong.
Best,
