06-19-2015 03:04 AM
I try to log data in PreUUT seq.
Even if i mark it in additional data pane, i don't see it in the report.
How should i do it ?
Solved! Go to Solution.
06-19-2015 05:33 AM
Reporting is a feature of the model.
Normally only the ResultList from MainSeqeunce is generated to the ReportFile.
That means if your stuff if in PreUUT must be reported to the UUT file you have to modify your model.
Depending on your requirements there a lot of possibities to do that.
A simple one that worked for me for specific SequenceFiles (Note: not for all ! ) :
Copy PreUUT's ResultList to a FileGlobals ATFER it has been performed by EntryPointSequence.
Add a Statement to your MainSequnce where you add the List from RunState.Root.FileGlobals. as element to Locals.ResultList
Thats all
Juergen
06-22-2015 02:56 AM
Ok - that should work.
Does that mean the process model "ignores" the "LOG" flag in the module definition when i'm in PreUUT ?
At least i can't see any changes when togling then flag.
06-23-2015 12:40 AM
