NI TestStand
Loading Numeric Data from Text File for Numeric Limit Test
I'm a brand new TestStand 2014 user.  Just downloaded the demo, successfully ran the computer.dll tutorial & the "Loading Limits From a Text File.seq" example; & am now attempting to build my own sequence from scratch.  I want to load a number from a text file using Property Loader.  The file contains this:
GGbeg
484
GGend
My Main sequnce contains 2 steps (see attachment):
Property Loader (which reads the text file & should store the number 484 in the variable Step.Result.Numeric, right?)
GG-numeric-test (which should test the number 484 in Step.Result.Numeric as the Data Source, right?)
But when I execute it, the Measurement shows "0" for the value instead of "484".  What am I doing wrong?  Thanks in advance for your help!
George
(4,176 Views)
Accepted by topic author funhistory
Hi George,
The text file needs be in the format, property loader step understands. Use the following in the text file to make it work:
GGbeg
<Step Name>    Result.Numeric
GG-numeric-test    484
<Locals>    Variable Value
<FileGlobals>    Variable Value
<StationGlobals>    Variable Value
GGend
In Tools menu of Sequence Editor, there exists "Import/Export Properties" tool, that helps in creating text files to be used with property loader step. I strongly recommend you to create new file using the tool and then edit the file to modify the values.
- Shashidhar
(4,171 Views)
Thank you so much!  I'm now able to adjust the numbers to get the desired results.  It is such a relief to see code work!
George
(4,145 Views)
