08-10-2014 11:50 PM
I'm a brand new TestStand 2014 user. Just downloaded the demo, successfully ran the computer.dll tutorial & the "Loading Limits From a Text File.seq" example; & am now attempting to build my own sequence from scratch. I want to load a number from a text file using Property Loader. The file contains this:
GGbeg
484
GGend
My Main sequnce contains 2 steps (see attachment):
Property Loader (which reads the text file & should store the number 484 in the variable Step.Result.Numeric, right?)
GG-numeric-test (which should test the number 484 in Step.Result.Numeric as the Data Source, right?)
But when I execute it, the Measurement shows "0" for the value instead of "484". What am I doing wrong? Thanks in advance for your help!
George
08-11-2014 12:58 AM
Hi George,
The text file needs be in the format, property loader step understands. Use the following in the text file to make it work:
GGbeg
<Step Name> Result.Numeric
GG-numeric-test 484
<Locals> Variable Value
<FileGlobals> Variable Value
<StationGlobals> Variable Value
GGend
In Tools menu of Sequence Editor, there exists "Import/Export Properties" tool, that helps in creating text files to be used with property loader step. I strongly recommend you to create new file using the tool and then edit the file to modify the values.
- Shashidhar
08-11-2014 08:54 AM
Thank you so much! I'm now able to adjust the numbers to get the desired results. It is such a relief to see code work!
George
