In my sequence file I have approximately 2500 lines. I have over 100 limits scattered about the sequence file. Is there a script that can assemble and list the limits in an organized format available? I am using TestStand 3.0.
You could use the Import/Export Tool to output the limits to a file.
Not sure if with TS3.0 whether there is a <All Sequences> option, if not you will have to select each Sequence and perform the export of the limits and append the result to the file.
