You could simply parse using the System.Management assembly in a .NET step.
Place down a .NET action step
Set the Assembly: to System.Management
Set the Root Class: to ManagementDateTimeConverter
Set the .NET Invocation: to ToDateTime(System.String).ToLongDateString() //there are other methods here that might be a better format
Pass your string (20160203072206.610798+060 probably as a variable) to the dmtfDate when your cursor is on ToDateTime(System.String)
Move your cursor to ToLongDateString() and put the variable where you want to store it in the Return Value
Let me know how it works. I'm shooting from the hip here. See attached image.
