Hi Mason! I'm not quite sure what you're asking. You have an Operator Interface in LabVIEW, and you want to see each step data and limit in that operater interface?
If your Operator Interface includes the test report, you can modify the test report to display the relevant information. See the TestStand Manual link I'm including below. There is a specific option called "include test Limits"
For example, after a Numeric step (or in the SequenceFilePostStep Callback) send your UI a custom message with something like "Measurement_HighLimit_LowLimit" and then in your UI, you need to parse that string and handle the information.
