How can I change the Label of a TS array element from my LabVIEW code??? Se picture added.
It is done when you insert at ”Multiple Numeric Limit Test” step in a test sequence and select “Edit Limits…” you get the “Edit Multiple Numeric Limit Test” dialog box. When this is closed with OK the Names of the Measurement Set is applied to the elements in Step.Result.Measurement. How can I do this from LabVIEW???
I am looking forward to hear from you.
Best Regards,
Morten Pedersen
CIM Industrial Systems A/S
