NI TestStand
LabVIEW module use DLL
In a teststand sequence file, it uses LabVIEW modules that call .NET DLL.  The DLL cannot be linked to the program.  If I were using LabVIEW only, I know that I can insert the DLL into a LabVIEW project and the VI in the project will know where the DLL are.  However, I am not sure about teststand.  Can someone help?  Thanks!
(4,035 Views)
Are you asking because you want to deploy the system? If yes, you should create a workspace and add the .NET DLL to your project as additional file. You can use the Deployment Utility to include the DLL in a MSI (Microsoft Installer).
If you are NOT asking in the context of a deployment, please elaborate your question....
Norbert
Norbert
Expert: Geometry
(4,002 Views)
Problem resolved.  The contractor forgot about the configuration for .NET 4 DLL.
(3,966 Views)
