10-17-2014 09:19 AM
In a teststand sequence file, it uses LabVIEW modules that call .NET DLL. The DLL cannot be linked to the program. If I were using LabVIEW only, I know that I can insert the DLL into a LabVIEW project and the VI in the project will know where the DLL are. However, I am not sure about teststand. Can someone help? Thanks!
10-20-2014 02:11 AM
Are you asking because you want to deploy the system? If yes, you should create a workspace and add the .NET DLL to your project as additional file. You can use the Deployment Utility to include the DLL in a MSI (Microsoft Installer).
If you are NOT asking in the context of a deployment, please elaborate your question....
Norbert
10-21-2014 09:12 AM
Problem resolved. The contractor forgot about the configuration for .NET 4 DLL.
