NI TestStand
LabVIEW V'sI containing TestStand API saved on different Windows versions
Hi.
I have a question regarding saving and loading of LabVIEW VI's that contains calls to the TestStand API in different versions of Windows:
Can it be true that if I create such a VI in e.g. 64 bit Windows 7 and then load it in 32 bit Windows 7 or XP with the exact same versions of LabVIEW and TestStand, the VI will need to be recompiled?
I am currently using LabVIEW 2012 SP1 f9 and TestStand 2012 SP1 f1.
Best regards
Jens Christian Andersen.
Best regards
CLA, CTA, CPI
(3,908 Views)
If the labview version is same then it need not be re compiled.
It will work with different versions of Windows (for both bitness 64\32 OS)
Ravi
(3,893 Views)
