11-25-2014 09:02 AM
Just migrated my test platform from TS2013 & LV2013 x32 to TS2014 x64 & LV 2013 x64. I now try to build a new deployment installer for my test stations, but the LV RTE SP1 F5 is not listed in the components for deployment even if it is correctly used as labview adapter in the Teststand sequence editor... why ?
I can see RTE SP1 F3, but not F5...
Please, see attached picture to see my teststand configuration (showing the labview adapter) and the list of components available in the deployment utility.
Thank you for help.
C.
Solved! Go to Solution.
11-26-2014 12:43 PM
Hello Christian,
Have you tried checking the RTE SP1 F5 driver in the "Components to Include" section? It looks like it simply hasn't been included.
Best wishes!
11-26-2014 12:54 PM - edited 11-26-2014 12:56 PM
Hi Amanda,
Please look carefully to the screenshot "Components.png" provided in my previous post. You will notify that the NI Labview RTE 2013 SP1 F5 is not available in the list of "components to include" ... Which is actually the issue I want to fix...
Thank you for help
C.
12-01-2014 03:29 PM
Christian,
This behavior was reported as a bug in November. Unfortunately there is no workaround at this time, but R&D is working to resolve the issue in the future.
12-04-2014 10:50 AM - edited 12-04-2014 10:51 AM
Thank you for the information.
As a temporary fix (in date of 2014-12-04), I manually installed the LV 2013 RTE SP1 F5 on the test station.
You can find the downloadable version here:
http://www.ni.com/download/labview-run-time-engine-2013-sp1/4539/en/
Thank you and have great day,
C.
