03-23-2005 04:05 PM
03-24-2005 08:10 AM
04-20-2005 03:54 PM
04-21-2005 11:42 AM
08-03-2005 06:49 AM
Seems like this thread has grown for a while...
Just stumbled onto this problem myself. I'm using LabVIEW 7.1 with TestStand 3.1. My question is about how the parallel model is structured. Why does the sequence "Create Test Socket Execution" inside "Initialize TestSocket" store the path to your test sequence inside "Runstate.ProcessModelClient.Path"??
I am new to TestStand so bear with me... It seems that this location is the same for all test sockets running. Why doesn't the path get stored in the "Parameters.ClientSequenceFilePath"? By putting it here, you can open and close sockets (I'm doing it by calling Process Model Sequences through LabVIEW, terminating and initalizing different testsockets and providing new sequence file paths). Now I can run completely different sequences through seperate test sockets running at the same time.
One thing I found is that you need to have desired sequence open in TestStand for this to work. Main question is why is the path taken from "Runstate.ProcessModelClient.Path"? Are there problems that I'm going to run into by changing this?
-Brad
