03-26-2013 12:47 PM
I am searching for a way to down convert sequence files from 2012 to 2010. Looking to do more then one at a time and would like to be able to down convert an entire folder.
03-26-2013 02:49 PM
This can be accomplished using the TestStand API using the following method to perform the save for previous function:
RunState.SequenceFile.AsPropertyObjectFile.WriteFile(WriteFileFormat_TestStand45)
You would just need to obtain an array of sequence file references, which is probably most easily done through a code module (such as the Recursive File List VI in LabVIEW). Be sure to call Engine.ReleaseSequenceFileEx on the references after performing the backsave.
03-27-2013 08:27 AM
Thanks Al B.
