11-02-2005 01:04 PM
11-03-2005 11:06 AM
11-03-2005 11:37 AM
11-04-2005 11:57 AM
11-04-2005 05:03 PM
Tyler,
When you open a sequence file using the Operator Interface, a Standard IO window also opens. This (the standard io) is one of the windows I want to place in a tabbed window.
Paul
11-07-2005 09:19 AM
11-07-2005 04:13 PM
Hmm. I'm not sure he is referring to that. I thought he might be referring to the CVI stdio window that is probably appearing because some of his CVI code modules write to stdout.
This window is created by the CVI runtime libraries. A TestStand operator interface, or any other application, has no idea that the window exists.
It is conceivable that you might use Windows SDK level functions to find the window handle to the CVI stdio widow and then reparent it inside a TestStand OI application. However, this is a mega-kludge that would surely generate an endless supply of new problems.
A better solution would be replace the calls in the code modules that output to stdio with wrapper functions you create to enable you to redirect the output wherever you like. You could then insert the output into the TestStand report, or send it to your OI via a custom UI message. Your modified OI could then display the text wherever it preferred, including within a new tab.
11-08-2005 12:53 AM
Maybe beardsdad could post an artist impression to give some idea what is after!
Regards
Ray Farmer
