02-27-2013 02:20 AM
The Sequence Analyzer is not available in the Custom TestStand Editor Mode GUI.
Is it possible to add the Sequence Analyzer to a menu in the custom TestStand Editor?
Is it possible to launch the sequence analyzer from a C# code module, this method is then called from a sequence call back.
Best regards
Patrick
02-27-2013 06:28 PM
From the TS Help:
TestStand Sequence Analyzer Application
Select Start»All Programs»National Instruments»TestStand»Tools»TestStand Analyzer or run <TestStand>\Bin\AnalyzerApp.exe to launch the stand-alone TestStand Sequence Analyzer application. Use this application to analyze projects outside of the TestStand Sequence Editor.
The sequence analyzer application window contains the following tabs:
Files—The files and directories to analyze.
Rules—The rules to use for analysis. Use this tab to enable, disable, and configure rules for analysis in the current project.
Options—Contains the project options that control the analysis and determine whether the sequence editor automatically saves the current analyzer project.
Messages—Contains the list of messages for the most recent analysis of the current project, sequence file, or workspace file. The sequence analyzer overwrites the content of the Messages tab each time you start an analysis session.
Analysis Summary—Contains a summary of the most recent analysis of the project.
Command-Line Usage
You can use the following command-line syntax to open an analyzer project:
AnalyzerApp.exe "C:\My Documents\MyProject.tsaproj"
05-18-2015 10:05 AM
HI;
Is it possible to get and display in listview of c# current sequence of teststand?
