NI TestStand
Insert menu item blank in sequence editor for new sequence
In TestStand 2.0.1, when I create a new sequence file using the sequence editor and right-click to insert a step, the Insert menu is greyed out.
If I open an existing sequence file, copy a step from it, and paste it into the empty sequence, then whatever that step was (let's say Action) becomes available on the Insert menu.
Is there any way to fix this other than re-installing TestStand? Any idea why this is happening?
Gizmogal
(2,686 Views)
This sounds like you have a problem with your type Palette files in sowe way.
Check out if you can read the ini files found in teststand\cfg\TypePalettes.
Regards
Ray Farmer
Regards
Ray Farmer
(2,678 Views)
