12-13-2007 09:41 AM
12-17-2007 01:53 AM
Hi Steve,
I have done this with C# take a look to this code
static bool DoSequenceCallStep( XmlNode nodeStep, Step step, SequenceFile seqFile, Engine engine)Parameter = Parameters[0];
Parameter = Parameters[1];
Parameter = Parameters[2];
Do not care about the XML stuff from the i get the values !
I think this code snipped could be useful your you because the procedure in LV is the same
Greetings from the lake of Constance, Germany
Juergen
12-17-2007 03:14 AM
12-19-2007 03:48 AM
12-19-2007 04:48 AM
Hi Saranya,
Good question, you have to implement a second component the AdapterApi.
1. Component: (In German Called: Verweis)
NationalInstruments.TestStand.Interop.API
Location: C:\WINDOWS\assembly\GAC_MSIL\NationalInstruments.TestStand.Interop.API\4.0.0.326__ad9244eb3b825cd8\NationalInstruments.TestStand.Interop.API.dll
2. Component:
NationalInstruments.TestStand.Interop.AdapterAPI
Location: C:\WINDOWS\assembly\GAC_MSIL\NationalInstruments.TestStand.Interop.AdapterAPI\4.0.0.326__ad9244eb3b825cd8\NationalInstruments.TestStand.Interop.AdapterAPI.dll
Juergen
07-16-2015 09:20 AM
Hi, is there a way to do that using C++ language?
Thank you for your help
04-06-2018 04:49 AM
How to do this using Labview.
I have inserted parameter into the TS.SData.ActualArgs.
But I am getting error in the module tab.
17500
Error Occured while trying to refresh edit panel SeqEdit.o
operation Failed.
(Continuous error pop up.have to close editor)
But I can see that parameter inserted in the TS.SData.ActualArgs.
Bharath
