NI TestStand
Icon folder / components directory
I want to change the components directory from default to another place (network).
I found this old post
The actual problem for me is right now also the icon directory.... but I could imagine that there will be problems with some of the others components.. so there should be a option to change the path to the components directory
Has anything changed (I am using TS3.1) ???
(3,206 Views)
I have the same problemSmiley Mad My workaround was to create a file on the network and then use SyncBack to periodically copy (backup) the contents from the network file to the local fileSmiley Tongue
SyncBack can be found here: http://www.2brightsparks.com/
Hope this helps.
kph
(3,193 Views)
Thanks for you answer....... I don't think that is the best solution... I think I will make a seq that synch 2 folders.. and do calls it from a callback... for instance in the LoginLogout callback.
What about NI do they have a comment to this problem ????
Kind regards Bojer
(3,121 Views)
