06-16-2006 04:45 AM
06-16-2006 12:26 PM
06-16-2006 01:07 PM
06-16-2006 05:44 PM
Emmanuel - I have placed a rebuild of the TestStand 3.5 TSIviSteps.dll file under ftp.ni.com/outgoing/TSIviSteps.zip . It contains a change to fix the problem. It should work with TestStand 3.1, but I have not tested it. Please let me know if this fixes the issue for you.
06-20-2006 04:09 AM
06-20-2006 11:04 AM
Marc -
Thank you for letting me know that it works. The fix is already in our code base so a future release will have it.
I am curious, does the TestStand array limit size cause a problem for you?
06-21-2006 04:57 AM
