NI Home
Cart Cart | Help
You are here:
Reply
Member
Arik
I would like to use a dll function in teststand. How do I pass parameters into this function that controls a tds210 tektronix scope via GPIB Interface.
In which way do I add the paremeters in teststand environment?
Could you send me an example please.
Thank you.
Arik.
Trusted Enthusiast
RayFarmer
Re: I would like to use a dll function in teststand. How do I pass parameters into this function that controls a tds210 tektronix scope via GPIB Interface.
Find attached a small example which should help solve your question.
It's based on an example on the NI web site for TestStand.
The dll function receives two variables adds them and returns the answer back in the second parameter. Looking at the TestStand sequence, two variables are defined in the Locals Group called NumA and NumB. These are passed to the Step. This can be seen if you look at the specification of the step. ie select the step, right-mouse click and select specify module.., there you will see the link to Locals.NumA and Locals.NumB.
All you need to do is add your tds210 instrument function.
Hope this helps
Ray
Ray Farmer
Member
Arik
Thanks for the help Ray, I appreciate it.
Arik
Trusted Enthusiast
RayFarmer
Hope this helps
Ray
Ray Farmer
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
