Hi Ian,
I believe you have spoken with James on this issue, however I wanted to reply here for the benefit of the rest of the community.
It is possible to remove the reference to the main sequence path and sequence file name by editing the xml style sheet.
In horizontal.xsl, search for and comment out all references to "Begin Sequence" and "End Sequence" to remove those mentions within the final report.
Then save this custom style sheet and referenced this by going to Configure > Results Processing in TestStand, and selecting in the configuration, XML Document, and for the Style Sheet select the custom .xsl file that you created. This can be seen in image 1.
Kind Regards
__________________________
Aidan H
Applications Engineer
National Instruments UK & Ireland
