NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
andrewc21
I use several Call Executables (calls a VB executable) with my main sequence. How can I pull out data and compare it without using Active X Automation Adapter?
Member
Roberto P.
Re: I use several Call Executables (calls a VB executable) with my main sequence. How can I pull out data and compare it without using Active X Automation Adapter?
There is no way of getting data back from an executable directly using the Call Executable Step type.
A good way of exchanging data with an executable is using ActiveX. With VB you can create an ActiveX executable or DLL.
Also, if you don't want to use ActiveX, you can generate a TXT file with Visual Basic and read it back in TestStand using the Limit/Property Loader step type.
Roberto Piacentini
www.ni.com/ask
Member
Darin
LabVIEW's System Exec function returns Standard Output and Standard Error strings. Are those 2 strings available for TestStand's Call Executable step? I am really only looking for similar functionality in TestStand that we have in LabVIEW..
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
