NI TestStand
I need a shortcut-key for "Configure VI...". How do I manage this?
From the my step context menu in my sequence editor, I would
like to use a shorcut key for "Configure VI..."
(like one exists for "Specify Module..." = Ctrl + M)
How do I do this?
Better, how can I set the mouse double-click to
call the "Configure VI..." instead of calling
the Step Properties Window?
Thank you again for your Help!
- Caribe -
(2,906 Views)
Well, this isn't really the answer you want and you probably already know it, but with the step selected you can use the menu accelerator by typing V to bring up the dialog.
The is the key with a picture of a popup menu on it. On my keyboard it is between the and the CTRL key.
(2,899 Views)
Oops, the message board removed what I had typed in angle brackets. Here it is again with different brackets:
Well, this isn't really the answer you want and you probably already know it, but with the step selected you can use the menu accelerator by typing [context-menu-key] V [enter] to bring up the dialog.
The [context-menu-key] is the key with a picture of a popup menu on it. On my keyboard it is between the [program-start-key] and the CTRL key.
(2,898 Views)
Also, Shift-F10 has the same function as the [context-menu-key].
(2,888 Views)
Isn't there really a way to change the
double click function in the sequence editor?
The "Configure VI..." context menu command is
almost the only one command that the sequence programmers
are going to use in our project. It would speed things
a lot and decrease complexity.
Thanks anyway! The context-menu-key I know already, but
it is not the perfect solution...
Nice day and thanks a lot!
- Caribe -
(2,879 Views)
