Hi Artur,
Much of TestStand 3.5 is the same as in the TestStand 3.0
manuals. The only major change from the 3.0 manuals is that User
Priveledges have changed. You can see the changes and new
features in 3.5
here.
This includes a gallery and description of the changes from 3.x to
3.5. Therefore, I would work through the manual that you have as
a good resource for learning TestStand. Also, the TestStand
Bookshelf also includes a number of different resources and tutorials
including
Using TestStand which walks through the basics as well as
Using TestStand with LabVIEW and
Using TestStand with LabWindows/CVI. You can reach the bookshelf from within TestStand by going to
Help>> Search the TestStand Bookshelf. This is a wonderful starting point for learning TestStand.
Caroline Tipton
Data Management Product Manager
