08-25-2015 11:14 AM
I created a sequence in teststand and have been messing with the user manager and now when I right cleck on the specific step in teh sequence editor it doesnt allow me to edit code anymore. I then oipened up an example and it did the same. I checked the user manager and it has the priveleges set to grant all so I am stuck. If I add a new step to the sequence and insert it and then go to the specify module tab, it doesnt allow me to create a VI either. Appears to be a privelege thing or something...Help
Solved! Go to Solution.
08-26-2015 01:42 PM
What is your LabVIEW adapter set to?
Is it set to Development Environment or is it set to Run Time Engine?
08-26-2015 01:57 PM
You hit th enail on the head. It was set wrong in the dialog
