I have a Sequence that launches a sequence in a New Thread that happens to launch some LabVIEW code. The problem is when the LabVIEW code finishes, it will not close even when the TestStand sequence terminates. Is there a way to tell this LabVIEW code to Exit, I've tried the Quit LabVIEW function, but that causes a C++ RunTime Error. The LabVIEW code does end though, and it is set in the VI properties to:
Checked - Show Front Panel When Called
Checked - Close Afterwardds if originally closed
The sequence call that the LabVIEW code is launched from has the following options:
- New Thread
Unchecked - Automatically wait for the thread to complete at the end of the current sequence
Unchecked - Initially Suspended
Unchecked - Use single threaded apartment
Any clues on this would be appreciated.
