Meanwhile i can use the propertyloader for Limits and Variables which are in a container of the teststep. What not worked was:
1.) setting the properties of a "Messagebox". For example the property "Button1Label". Why is this not working?
2.) The second thing what is not clear: Do i need for each sequence an own property-loader? I tested it with a sequence with one subsequence. Does the subsequence needs its own property-loader?
Currently the import-csv-file looks like this:
Start Marker,,,
<Step Name>,Limits.Low,Limits.High,Cont.Voltage
TestStep_1,1,2,4
TestStep_2,8,16,32
End Marker,,,
When Teststep_1 and Teststep_2 are both in mainsequence then it works. When i copy Teststep_2 in a subsequence then i get an error (-18).
Any ideas about my two questions?
