05-25-2006 01:18 AM
05-25-2006 01:42 AM
Hi Jacky,
http://forums.ni.com/ni/board/message?board.id=330&message.id=2419&query.id=86917#M2419
http://forums.ni.com/ni/board/message?board.id=330&message.id=1610&query.id=86919#M1610
Here are a couple of examples that Get or Set the Run Mode of a step.
There are also examples on the NI website for TestStand, that will obatin all the steps of a sequence / sequence file,
which should help for building the basic loop to get a step,
check its Step Type (there is an example of this on website),
to decide whether to modify the Step property or not.
The tricky bit is whether your sequence call steps call sequences in the sequence file or in an external sequence file.
Hope this gets you started.
What version of TestStand are you using?
Regards
Ray Farmer
