NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Vincent90
How to personalize your generation report ?
I want to make group/ungroup report.
Like
      +Robot1 PASS/FAIL
              +DI    PASS/FAIL
                         DI0  PASS/FAIL
                         DI1  PASS/FAIL
                         DIn
              +DO  PASS/FAIL
Anyone got an idea about that kind of generation report ?
Best regards
Vincent
Active Participant
Rodéric
Re : How to personalize your generation report ?
The best way (from my point of view) would be to override the test report callback. Then create a custom report using LabVIEW steps.
Another way would be to Browse the resultlist container to extract the needed infos.
Hope this helps,
Rodéric L
Certified LabVIEW Architect
Member
Vincent90
Hi Rodéric,
Can you explain further how to create a custom report using Labview steps ? Is it working with .ini files ?
I am barely new in that Test Stand programming so forgive me my lack of knowledge.
BR,
Vincent
Active Participant
DavidS.
Hi Vincent,
I think you could use the step "Additional Results" in your sequences to customize your report.
Hope this help.
Sincerely
David S.| Certified LabVIEW Associate Developer
National Instruments France
Journées Techniques LabVIEW 2012 : du 27 septembre au 22 novembre
2 sessions en parallèle : Débuter a...
Member
Vincent90
Hi David,
I don't have hard yet to test that but it seems to fit my application. I let you know.
In Configure/Report Option i set up the following stylesheet ; expand.xls
That allows me to check my PASS/FAIL Sequnces in the format description above.
In my report i want to keep only my final test ; card is ok/nok. How to delete "if loop" pass/fail or "message" pass/fail report generation ?
BR,
Vincent
Active Participant
Rodéric
There is a check box called "Record results?" for each step.
Rodéric L
Member
Vincent90
Yes indeed, for each addtional results set up.
But the basic report contain If loop report. I want to delete them in order to display only card PASS/FAIL.
You can find attached the kind of report Test Stand provides. As i don't have my hard yet. The report should display nothing. Here it is checking if If loop have passed or failed. I don't want that in my report generation.
BR
Vincent
Member
Vincent90
Hi, I found the answer !
You click on your step/properties/Run Options/disable Record result
I have a last question, how does the template window work ? Seems you have to import .ini files but what for, what is the use ?
BR
Vincent
Active Participant
~jiggawax~
Templates are used to store a step or variable or sequence that you will want to use repeatedly.
For instance I always create a Statement Step.  Then I turn off the record results (as you have figured out).  Then I place that in my templates.  Then the next time I use a Statement Step I pull it from my templates.  That way I don't have to keep turning off the record results.  It is very rare that I record a Statement Step.
Hope this helps,
jigg
Test Development Engineer
L-3 Communications
Member
Vincent90
Hi Jigg,
Thank you very much for that feedback.
Test Stand begin to be more and more familiar to me.
Is there a way to get a report which fill in automatically, PASS / FAIL / NOT TESTED YET
The cabinet i am working on got 4 controllers with 20 cards on each. (80 cards on the entire cabinet, 960 I/O)
I need that kind of functionality in order to be sure all I/O have been tested.
Any idea about this (using expand/collapse graphical viewer)?
BR
Vincent
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
