04-08-2014 01:04 AM
I have certain fixed steps to be executed for many test sequences at part of Setup and Cleanup group. I have created sequences for each group(init.seq and Release.seq) and called them in another sequence (Template.seq)
If Template.seq opens when I press Ctrl+N, reoccuring activity time can be saved.
I have tried adding Template.seq in Template Tab but that too requires deleting MainSequence(which gets create when Ctrl+N is pressed) and then adding this Template.seq from template tab.
You find the sequence is the attahment
Is there is way to meet this requirement?
Anand Trivedi
Application Enigneer
Woodward Inc.
04-08-2014 03:01 AM
Anand,
do you refer your question to the NI SequenceEditor or a custom UI with developer capabilities (e.g. full-featured Editor mode)?
Norbert
04-08-2014 03:28 AM
I am referring for NI Sequence Editor.
Anand Trivedi
04-08-2014 06:43 AM
Anand,
there is no way i know of to change the New Sequence File menu bar option to spawn a custom template sequence file instead of an empty one.
What you can do is to provide a tool you add to the TestStand tools menu.
Norbert
04-08-2014 07:12 AM
Norbert,
What I mean is not changes in menu.
When Ctrl+N is pressed a default blank sequence will open. Instead of that blank sequence is there option to load another sequence, is what I am looking for.
Anand
04-08-2014 09:22 AM
You could create a menu item which does this either using a process model configuration entry point or a tool menu item, but there is no way to create such an item with a shortcut key, so it's not possible to make Ctrl+N do what you want. You might want to post to the idea exchange to request such a feature.
-Doug
