How to make Message PopUp result Pass/Fail ?
A message Popup step gives you the option to select Post Actions as response to a button pressed.  Within the options I see a Termination.  In my case I don't like to terminate the sequence but rather designate it as Fail/Pass step. (instead of Done or Termination)
Can it be done
Rafi
(3,242 Views)
Rafi,
I have attached a simple example. Hope it helps.
Regards
Ray Farmer
Regards
Ray Farmer
(3,237 Views)
