09-20-2005 12:56 PM
09-21-2005 12:55 AM
09-26-2005 12:38 PM
09-27-2005 01:21 PM
09-27-2005 01:41 PM
09-27-2005 02:19 PM
You're talking about two different things. Test data is not the same thing as sequence documentation. The format of test data is selected from Configure>Report Options and ASCII text is one of the options you can choose.
As far as using a spreadsheet to create a test sequence, I suspect that this could be accomplished if that's what you want. Look at the shipping example called Sequence Builder Tool to get a start. TestStand may be doings things a little different than the competition but TestStand also allows you do many things in different ways.
12-21-2005 04:38 AM
