NI TestStand
How to include LabView Instr.llb in a TestStand deployment?
I want to deploy my Test Stand sequenze file. When i install the deployment and want to let run it shows that it can t find all of the sub VIs whitch i used direct from LabView. For example: VISA Configure Serial Port (Instr).vi or Check if File or Folder Exists.vi . How to include this VI s to the installer?
(3,406 Views)
Depending on your settings, those should already be part of the deployment.
You miss the dependencies from vi.lib, instr.lib and/or user.lib. In the worst case, you will have to create custom Source Distributions in LV to pack those components. When configuring those, you have to make sure that the checkbox "exclude vis from the vi.lib, user.lib and instr.lib" is NOT checked (by default it is).
Norbert
Norbert
Expert: Geometry
(3,401 Views)
Accepted by topic author Alteschwed
It s solved. All this VIs are in the Folder: Support VIs whitch is createt automatically by installing.  Thanks
(3,397 Views)
