10-19-2006 11:39 AM
10-20-2006 04:45 AM
if during your sequence running through you know which jpg etc you want to display, then register for a UI message callback in the normal way (from the execution manager or application manager reference to the register event callback node and select the event as uimessage) and pass in the reference to a picture control to the User parameters. Then create the callback VI from the vi ref input.
You need to then post a ui message from your sequence that passes either the path of the file in the string part or a handle to the sequence context so that in the callback vi you can get hold of that path and use LV to load the file and display it in the string.
Hope that makes sense.
Sacha Emery
National Instruments (UK)
