12-30-2013 12:21 AM
I'd like to show all the names of the steps within a sequence or a group.
I wonder if there is a simple function which can be used directly, such as RunState.PreviousStep.Name.
I tried via a foolish way to append each step name, though it shows all the step names but I still think there is a simple function can access all the step names.
Can anyone give me some suggestion, thanks a lot!!!
Solved! Go to Solution.
12-30-2013 11:29 AM
I've doctored up your sequence a little. But yes you have to loop.
Also, what format do you want the names in?
Hope this helps,
12-31-2013 01:25 AM
Hi, Jigg,
Thanks to your reply.
You use a simple and compact form to work it out.
I still wonder if there is an API function can return all the step names in a form of array instead of loop.
What do you think?
12-31-2013 08:17 AM
There is no way to do this without looping. At least not in 2010 SP1.
Sorry.
