Does anyone know of a way to search steps by name or type, and replace the step itself with a different step? I've been trying to accomplish this with the Find/Replace in Files dialogue, but haven't been able to figure it out. To clarify, my goal is to find all ActiveX controls with a specific name within a single sequence file, and replace them with a similar .NET control. Doing this manually would be very time consuming.
There's no pre-made tool that does this in TestStand. However, what you need can be achieved pragmatically.
I found this example that should be helpful if you have TestStand 3.1 or later. You will need to make small changes to replace a ActiveX with a .NET as the example now changes it to None. You can add other steps to make other changes if needed.
Hope this helps.
Tarek B Applications Engineer National Instruments
