04-14-2015 12:17 AM
Background
I have 5 tests running in a For-Loop. Each loop iteration corresponds to one row in my database table. These tests use a Pre Expression to set the Step Name.
For some loop iterations, it doesn't make sense to run 1 out of the 5 tests. Here, I use a Precondition to skip the test.
Problem
When the Precondition fails, the Pre Expression doesn't run. That means the Step Name remains unchanged from the last iteration which ran the test. So, the report shows the wrong name being skipped.
Possible solutions?
The ideal solution is to not have the Skipped tests appear in the report at all. Is there a way to achieve this?
If not, we can live with the line that shows "Skipped" in the report, if the Step Name is updated to match the others. Is there a way to achieve this?
Or, are there any other suggestions?
Thanks!
Solved! Go to Solution.
04-14-2015 04:23 AM
There is an option in report settings.
Its under Include step results --> Result filtering Expression :
You need to give this : Result.Status != "Skipped"
This will avoid skipped tests in the report.
Hope this helps.
Ravi
