I am using TestStand v3.5.
For some special purpose, need to copy the primary key to a new column in the same table?
For example, in defalut schema, I want to copy UUT_RESULT.ID to UUT_RESULT.KEY, where KEY is a newly added column.
Note: ID is still the column to store primary key, but KEY is a common column.
Is there any simple to make it happen?
Thanks a lot for your help.
