01-11-2006 05:00 AM
axExecutionViewMgr.GetCaptionText(CaptionSources.CaptionSource_NumberOfSteps,true,""); ( but it returns null i used it in precommand event of appln. mgr.)
but the teststand should provide a event so that i can update the progressbar value according to number of steps/ steps completed in UI right??
2. The functionality of ABORT will abort the current execution. but when i say restart it should restart from step that is being aborted. but the current restart functonality provided in test stand restart from very first step of sequence. is there any way to achieve this?.
3. I try to run sequence file programmatically using the following code
NationalInstruments.TestStand.Interop.API.Engine eg= axApplicationMgr.GetEngine ();
NationalInstruments.TestStand.Interop.API.SequenceFile s =eg.NewSequenceFile ();
s.Path ="D:\\Program Files\\National Instruments\\TestStand 3.1\\Examples\\Demo\\CreateDeleteUsers\\CreateDeleteUsers.seq";
eg.NewExecution (s,"CreateDeleteUsers.seq",
null,true,0,null,null,null);but it show the following error
An unhandled exception of type 'System.Runtime.InteropServices.COMException' occurred in TestExec.exe
Additional information: Unknown function or sequence name 'CreateDeleteUsers.seq'.
have i anything missed in the code??
Thanks in Advance
Srini
01-12-2006 10:09 AM
01-12-2006 12:12 PM
01-12-2006 02:43 PM
// run the current sequence
this.axSequenceFileViewMgr.GetCommand(CommandKinds.CommandKind_RunCurrentSequence).Execute(true);
// run an execution entry point (Test UUTs is typically at index 0 and Single Pass is typically at index 1)
this.axSequenceFileViewMgr.GetCommand(CommandKinds.CommandKind_ExecutionEntryPoints_Set, 1).Execute(true);
Alternatively, you could create an execution with ApplicationMgr.GetEngine().NewExecution, passing in the SequenceFile that the OpenSequenceFile method returns. If you are modifying/creating an OI application, I recommend reading Chapter 9 of the TestStand Reference manual if you haven't already.
