NI TestStand
How to create Custom Step Types: Is there any example?
Dear all,
I remember years ago I've read an NI page with  a detailed procedure for creating Custom Step Types. Additional LV code and .DLLs were provided for download, but now I'm not able to find anything anymore...
The example was about creating a new Extended Numeric Limit Test type.
 Could anybody help me?
Thanks in advance!
Giovanni P.
Certified TestStand Developer
(5,056 Views)
Giovanni,
This might be the example you were thinking about but it's a bit outdated:
Archived: Creating Custom Step Type to Check Return Values within Custom Margins
A good high level document for this is Best Practices for Custom Step Type Development. We also install several custom step type exapmles in the following directory -
%TestStandPublic%\Examples\Custom Step Types
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(5,029 Views)
Hi Trent,
In the past I had downloaded the attached PDF document from the NI site. Even if it refers to an older TestStand version it's quite accurate and it would be fine, but I can't find the DLL the example refers to (which was supposed to be linked to the page).
The DLL provided the functions to be executed for the Edit and pre-step Substeps..
(5,012 Views)
I think I found it. See the attached zip.
-Trent
(5,001 Views)
Accepted by topic author giovanni.alfamation
hank you very much Trent!!
(4,977 Views)
Sorry Dear Trent,
but Not executable.the extendedlimitsdialog.uir file is missing
(4,250 Views)
