08-02-2013 04:17 AM
I need to send RS232 command in hexa format (type - string), but in teststand it is taking as ASCII characters.
Tried in Labview, working fine, but in teststand i m facing difficult.
Please help !
Thank you 🙂
08-02-2013 04:17 AM
Sorry it is Normal string to Hexa string
08-02-2013 05:25 AM
08-02-2013 06:09 AM
Example : 02000111800151CA , which is of 8byte. This same hexa valu i need send through RS232.
when trying with Labview i changed the display format to Hexa and transmitted the command, its working. But how to do that in Teststand, is the question.
08-02-2013 06:14 AM
08-02-2013 06:15 AM
08-02-2013 06:45 AM
I m using 5.0 and the final output should be hexa string. Convert from number/string no matter.
08-02-2013 07:05 AM
