NI TestStand
How to collect the results of one step and utilise them in some other steps in the same sequence
Hello
I am new to the Teststand.
I am using labview8.0 with teststand 3.1
Plz get me solution for the below
I am configuring the serial port resources like resource name, baud rate etc..,I made the initialization using setup task.I made serial port write and serial port read as independant vi's in labview and called them from teststand as steps.Now i need the same resource name appear in some other steps in the sequence .how can i get them using teststand commands instead of specfying them at each step.
Also how to pass values or results obtained from one step to some other step in the same sequence using teststand commands.And I want the results to be printed in the report.
Plz suggest the solution
Also help me in parameter passing
Thanks and Regards
      Kiran Kumar
(2,868 Views)
Kiran,
if you work with external resources (like serial), you should controll the handle within teststand. So you would retrieve and configure the resource in a module (most often action- or pass/fail-step) and pass the handle to TestStand. Please check if the handle is a cluster, an object reference, a string or simply a number (you have to create an appropriate variable!). Passing the handle should be done as parameter of all modules using this resource.
Since you cannot be sure if the handle, which resides now in TestStand, is valid, you propably want to retrieve the resource in a pass/failstep and then use preconditions for each further step using this resource.
Example:
Get Serial Port
Read Serial Port (Precondition: Get Serial Port PASSED)
Write Serial Port (Precondition: Get Serial Port PASSED)
Close Serial Port (Precondition: Get Serial Port PASSED)
hope this helps,
Norbert B.
Norbert
Expert: Geometry
(2,842 Views)
Hi Norbert
Can to tell me how to get the visa resource name(data type-Labview io control) in the steps using teststand utilities like get/set teststand prop. value.
i created the local>>insert local>> type>>lv>>lviocontrol
and then now i need to use teststand utility in some other step to collect the resource name .I tried this but showing errors
Kiran
(2,839 Views)
You can pass it direct to and from the VI via the VI's connector pane.
Regards
Ray Farmer
Regards
Ray Farmer
(2,835 Views)
