05-02-2013 02:05 PM
From the TestStand help:
GetNumSubProperties Method
Syntax
PropertyObject.GetNumSubProperties ( lookupString)
Return Value
Long
Number of subproperties within the property specified by lookupString.
Purpose
Returns the number of subproperties directly within the property the lookupString parameter specifies.
Parameters
lookupString As String
[In] Pass an empty string to denote the PropertyObject to which the method applies, or pass the name of a subproperty within the PropertyObject. Refer to Lookup Strings for more information about the strings you can use.
05-15-2014 01:49 PM
This is not working, and it is from the test stand help.
Locals.BarcodeLengthAct = GetNumElement (Locals.BarcodeStrings[0]
05-15-2014 02:14 PM
fullmanido,
Try this instead:
Locals.BarcodeLengthAct = GetNumElements (Locals.BarcodeStrings[0])
I changed "GetNumElement" to "GetNumElements" and closed the parenthesis. I believe this will work properly. Let us know if you run into any more trouble with it!
05-16-2014 11:10 AM
If the array you want the size of is Locals.BarcodeStrings you should use this instead:
Locals.BarcodeLengthAct = GetNumElements (Locals.BarcodeStrings)
Not sure why you had [0] in there. That doesn't make sense unless you have an array of arrays and you want the size of the first array in an array of arrays.
-Doug
