08-22-2005 04:26 PM
08-23-2005 07:42 AM
Hello Valen,
The answer depends on how the paths for the
If the path for a VI is an absolute path, eg. C:\Documents and Settings\User\My Documents\TestVIs\myFirstVI.vi, then TestStand looks for the VI exactly on that path. In this case, you would need to edit the particular step to edit the path.
If, on the other hand, the path to the VI is relative, then TestStand will look along paths created from concatenating the Search Directories with the relative path. That is, if the path for a step’s VI is TestVIs\myFirstVI.vi, and the first Search Directory is the path of the sequence file, then TestStand will first look for <path of the seq file>\TestVIs\myFirst.vi. In this case, you can change the location of the VI without editing the step as long as TestStand can find TestVIs\myFirstVI.vi starting in one of the Search Directories.
In other words, if every step of your sequence has a relative path for its VI, then yes, you can add the “main” path to all of the
You can view and edit the TestStand Search Directories. Selecting Search Directories from the Configure menu launches the Edit Search Directories dialog. Press Help in this dialog for information on the fields in this dialog. In the Edit Search Directories dialog, you will notice that the first directory by default is the “Current sequence file directory”.
Eric
08-24-2005 09:39 AM
08-25-2005 01:56 PM
Hello Eric/Doug,
Thanks a lot for the advice.
Valen
